Install the Access Point on a Wall Using
ACC-MBO-KT-AX Adapter, KT-147407-02 Bracket Wall Parts, and KT-150173-01 Extension
Arm
Learn how to install an outdoor
access point on a wall using ACC-MBO-KT-AX adapter, KT-147407-02 bracket wall parts, and
KT-150173-01 extension arm.
The following hardware is required for outdoor access point wall installation using
the -MBO adapter, KT-147407-02 bracket parts, and the KT-150173-01 extension arm:
One outdoor access point
One ACC-MBO-KT-AX adapter
Four M5 hex bolts
Flat part of the KT-147407-02 bracket
1-axis tilt part of the KT-147407-02 bracket
Four M6 hex screws with split washer and hex nut
Four M6 head size screws
Four M6 screws
One KT-150173-01 extension arm
Two hex-head M12 stainless-steel screws and nuts
Four M6 hex-head screws and optional screw-in anchors
The ACC-MBO-KT-AX adapter is used with outdoor access points to add a tilt to the
access point after installation. For wall installations, the -MBO adapter is used in
combination with the KT-147407-02 bracket wall parts. To add extension to your wall
installations, use the KT-150173-01 extension arm in combination with the
KT-47407-02 bracket parts.
arm
Attach the ACC-MBO-KT-AX adapter
to the access point using four M5 bolts.
Torque the M5 bolts to 25 in-lbs.
Attach the flat part of the KT-147402-02 bracket to the ACC-MBO-KT-AX adapter
using four M6 hex screws, split washers, and hex nuts.
Torque the M6 screws and nuts to 45 in-lbs.
Align the 1-axis tilt bracket part inside the flat part of the KT-147407-02
bracket, and attach the flat bracket to the 1-axis tilt bracket using four M6
screws.
Set the desired angle on the tilt bracket and tighten the screws to a torque of
45 in-lbs.
Using the KT-150173-01 extension arm as a template, mark and drill four hole
centers on a flat surface.
The holes must be within the circular cuts in the end of the flange.
Attach one end of the KT-150173-01 extension arm to the 1-axis tilt bracket
using two hex-head M12 stainless-steel screws and two hex-head M12
stainless-steel nuts through the two large circular holes on the KT-150173- 01
extension arm.
Torque the M12 bolts and nuts to 22 ft-lbs.
Attach the KT-150173-01 extension arm, that now has the access point mounted on
the other end, to a flat surface using four M6 size hex-head screws.
Use screw-in anchors with the four M6 hex-head screws when you mount the
bracket on a wood surface and use concrete anchors for concrete surface.
