Details about print templates for the AH-ACC-BKT-AX-WL bracket.
For easy installation, you can print and use the AH-ACC-BKT-AX-WL bracket template. Download your printable template from the links provided in this topic and select your print settings based on your location.
The print preview is available in the print window. Verify that the page setup is as per the specifications.
When you print the template on an office printer, the access point edges will be cut, but it will not modify the scale of the template.
If you are using an industrial printer, cut the bleed area for the right template size.
If you are unsure about the printed template size, use a ruler to measure the scale provided in the template or place the access point over the template to measure the size.The print preview is available in the print window. Verify that the page setup is as per the specifications.
Use a ruler to measure the scale provided in the template or place the access point over the template to measure the size.The print preview is available in the print window. Verify that the page setup is as per the specifications.
