This command only initiates the search process. It does not return the actual GPS coordinates. To view the coordinates, execute the following command:
show gps coordinates {on <DEVICE-NAME>}
For more information, see gps (show command).
Access Point — AP7662
gps search [start|stop] {on <DEVICE-NAME>}
gps search [start|stop] |
Triggers the GPS hardware to start or stop the GPS coordinates search process
Note:
Unless explicitly stopped, the GPS coordinates search continues at regular intervals. |
on <DEVICE-NAME> |
Optional. Specifies the AP whose geographic coordinates are to be
determined. Use this option if executing the command on the
controller or virtual controller to which the AP is adopted.
Note:
If you do not specify a device name, the system initiates the search on the logged device. And if the logged device is not an AP7662 model access point, an error message returns. |
ap7662-8BDE4D#gps search start Started GPS Search, please check back after some time. ap7662-8BDE4D#
ap7662-8BDE4D#show gps coordinates GPS Search is in progress. Last location recorded at UTC time : Mon Apr 23 22:10:54 2018 : Latitude : 13.036N Longitude : 77.3827E ap7662-8BDE4D#
