Configure the bypass LSP by specifying a unique name. The name must be unique across the regular LSPs and the bypass LSPs in the system. The
		bypass-lsp command creates an instance of the bypass LSP with its administrative status as down. You must configure a few of the mandatory parameters in order to enable (admin up) the bypass LSP. You can delete the bypass LSP by using the
		no bypass-lsp form of the command.
		To configure the static bypass LSP, complete the following steps.
		  Enable the device for configuration.
		  Enable the MPLS router.
			 device(config)# router mpls
		  Configure the bypass LSP with the unique static bypass LSP name of my-bypass-lsp.
			 device(config-router-mpls)# bypass-lsp my-bypass-lsp
		The following example shows how to configure a static bypass LSP with a unique bypass LSP of my-bypass-lsp.
		device>configure
device(config-router-mpls-bypass-lsp-my-bypass-lsp)#
