The user can exercise control over the paths used by an LSP by setting the select mode and by specifying a preferred path using the select-path command.
By default, an LSP with primary and secondary paths configured immediately uses the primary path. When the primary path fails, a secondary (redundant) path is used. When the primary path comes back up, traffic reverts to the primary path and the secondary (redundant) path returns to a back-up state. However, path selection can be configured to operate in any of the following three modes:
manual select mode - In this mode, traffic is switched to a user-specified path after the selected path has stayed operating in the working state for at least the amount of time specified in the revert-timer configuration. In the manual select mode, traffic stays on the selected path as long as the path remains in working condition and only switches to an alternative path, such as the primary path when the selected path experiences a failure. Once the selected path comes back into working condition for the amount of time specified by the revert-timer configuration, traffic is switched back.
When an LSP is configured in manual select path mode with at least one other hot standby secondary path, the operation is as follows: when the selected path goes down, the system tries to bring up one hot standby secondary path to protect the primary path, but when the selected path is up, system brings down the hot standby secondary path since the selected path is already serving as a hot standby for the primary path.
unconditional select mode - In this mode, traffic is switched to and stays on the selected path regardless of the path‘s condition even when it is in a failure state. The main difference between manual and unconditional select mode is the test of the working condition of the user selected path. When configured in unconditional mode, the router starts the signaling for the selected path if has not already done so and brings down all other paths; this includes the primary path and the path carrying traffic when it is not the selected path. Because the speed at which the selected path comes up cannot be guaranteed, traffic forwarding might be disrupted.
The auto select mode and manual select mode configurations use the revert-timer configuration.The following steps configure the LSP named samplelsp with a primary path named pathprimary and two secondary paths named pathsecondarya and pathsecondaryb . The path named pathsecondaryb is configured as a selected path in the manual select mode.
The following example configures the LSP named samplelsp with a primary path named pathprimary and two secondary paths named pathsecondarya and pathsecondaryb . The path named pathsecondaryb is configured as a selected path in the manual select mode. After the parameters modification are made to the LSP, the select mode is changed to unconditional, and the traffic is switched to the pathsecondaryb path.
device# configure device(config)# router mpls device(config-router-mpls)# lsp samplelsp device(config-router-mpls-lsp-samplelsp)# primary-path pathprimary device(config-router-mpls-lsp-samplelsp)# secondary-path pathsecondarya device(config-router-mpls-lsp-samplelsp)# secondary-path pathsecondaryb device(config-router-mpls-lsp-samplelsp)# select-path manual pathsecondaryb device(config-router-mpls-lsp-samplelsp)# commit device(config-router-mpls-lsp-samplelsp)# select-path unconditional pathsecondaryb
Configuration changes made to the select mode do not take effect for an already enabled LSP until the change is activated implicitly using the commit command, explicitly using a reoptimize command, or a system reboot is performed.
When the user configures a primary path to be the selected path, a message is generated that states that it is already the default system behavior because the primary path is the default preferred path. In this instance, no configuration information is saved in the configuration file.
