Configuring a bypass LSP re-optimization timer
The user can configure a bypass LSP re-optimization timer on an adaptive bypass using the reoptimize-timer command.
To configure the re-optimization timer, complete the following steps.
  1. Enable the device for configuration.
    device>configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Configure the bypass LSP with the unique static bypass LSP name of my-bypass-lsp .
    device(config-router-mpls)# bypass-lsp my-bypass-lsp
  4. Configure the re-optimization timer. In this example, the timer is set to 400 seconds.
    device(config-router-mpls-bypass-lsp-my-bypass-lsp)# reoptimize-timer  400
The following example combines the steps above to configure a static bypass LSP with a unique bypass LSP name of my-bypass-lsp and configures the re-optimization timer to 400 seconds.
device>configure
