To display IP Information for a specified VRF, enter the following command at any level of the CLI.
device# show vrf Total number of VRFs configured: 1 Status Codes - A:active, D:pending deletion, I:inactive Name Default RD IFL ID vrf|v4|v6 Routes Interfaces a 1:1 131071 A | A| A 14 Total number of IPv4 unicast route for all non-default VRF is 12 Total number of IPv6 unicast route for all non-default VRF is 2 device# show vrf a VRF a, default RD 1:1, Table ID 1 IFL ID 131071 Label: (Not Allocated), Label-Switched Mode: OFF IP Router-Id: 0.0.0.0 No interfaces No Export VPN route-target communities No Import VPN route-target communities No import route-map No export route-map Address Family IPv4 Max Routes: 5120 Number of Unicast Routes: 12 No Export VPN route-target communities No Import VPN route-target communities Address Family IPv6 Max Routes: 128 Number of Unicast Routes: 2 No Export VPN route-target communities No Import VPN route-target communities
Syntax: show vrf vrf-name
The vrf-name parameter specifies the VRF that the user wants to display IP information for.
This field... |
Displays... |
VRF Name |
The name of the VRF. |
Default RD |
The default route distinguisher for the VRF. |
Table ID |
The table ID for the VRF. |
Routes |
The total number of IPv4 and IPv6 Unicast routes configured on this VRF. |
Label |
Display the unique VRF label that has been assigned to the specified VRF. |
Label Switched Mode |
Displays when Label Switched Mode is ON or OFF. |
Max routes |
The maximum number of routes that can be configured on this VRF. |
Number of Unicast Routes |
The number of Unicast routes configured on this VRF. |
Interfaces |
The interfaces from this Extreme device that are configured within this VRF. |
Export VPN route-target communities: |
The export route-targets that are configured for this VRF. |
Import VPN route-target communities |
The import route-targets that are configured for this VRF. |
Import route-map |
The name of the import route-map when any that is configured for this VRF. |
Export route-map |
The name of the export route-map when a route-map has been configured for this VRF. |
