Configuring RSVP Bundle Messages
When RSVP bundle messages are enabled on an interface, the device attempts to combine multiple outgoing RSVP messages on that interface into bundles to reduce overhead.
RSVP bundle messages are disabled by default for all interfaces. To enable bundle messages on an interface, complete the following steps.
  1. Configure the device.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable MPLS-capable interfaces and specify the selected individual ethernet interface.
    device(config-router-mpls)# mpls-interface ethernet 0/13
    In this example, the specified ethernet interface is 0/13.
  4. Enable LDP parameter configuration.
    device(config-router-mpls-eth-0/13)# rsvp
  5. Enable RSVP refresh reduction in the specified interface (0/13) with a bundle send delay of 20 milliseconds.
    device(config-router-mpls-eth-0/13-rsvp)# refresh-reduction bundle-message bundle-send-delay 20
    The bundle-send-delay option specifies the maximum period (in milliseconds) that an outgoing message can be delayed in order to create a multi-message bundle before sending. This delay is retained for the interface even when bundle messages are disabled.
The following example enables RSVP bundle messages on interface 0/13 with q bundle-send-delay of 20 milliseconds.
device# configure
When the RSVP neighbor does not support refresh reduction, the interface does not bundle messages even when bundle messages are locally enabled. Use the no version of the command to disable RSVP bundle messages on this interface.
Summary refresh is a more effective tool for RSVP refresh message overhead reduction.
