RSVP Message Authentication is disabled by default. This authentication method uses MD5 for an MPLS VE interface.
Complete the following steps to configure RSVP message authentication for MPLS interface ve 100.
device# configure
device(config)# router mpls
device(config-router-mpls)# mpls-interface ve 100
device(config-router-mpls-if-ve-100)# rsvp
device(config-router-mpls-if-ve-100-rsvp)# authentication key private
in this example, the variable private specifies a text string of up to 64 characters that is encrypted and used for RSVP message authentication.
The following example configures RSVP message authentication using MD5 for a MPLS VE interface.
device# configure device(config)# router mpls device(config-router-mpls)# mpls-interface ve 100 device(config-router-mpls-if-ve-100)# rsvp device(config-router-mpls-if-ve-100-rsvp)# authentication key private
