Displaying summary route information
To display summary statistics for all the VPNv4 routes in the device‘s BGP route table, enter a command such as the following at any level of the CLI.
        device# show ip bgp vpnv4 routes summary
  Total number of BGP routes (NLRIs) Installed     : 184
  Distinct BGP destination networks                : 184
  Filtered bgp routes for soft reconfig            : 0
  Routes originated by this router                 : 4
  Routes selected as BEST routes                   : 184
  BEST routes not installed in IP forwarding table : 0
  Unreachable routes (no IGP route for NEXTHOP)    : 0
  IBGP routes selected as best routes              : 90
  EBGP routes selected as best routes              : 90
Syntax: show ip bgp vpnv4 routes summary
This display shows the following information.
Table 1. BGP VPNv4 summary route information
This field...
Displays...
Total number of BGP VPNv4 routes (NLRIs) Installed
The number of BGP VPNv4 routes the device has installed in the BGP route table.
Distinct BGP VPNv4 destination networks
The number of destination networks the installed routes represent. The BGP route table can have multiple routes to the same network.
Filtered BGP VPNv4 routes for soft reconfig
The number of route updates received from soft-reconfigured neighbors or peer groups that have been filtered out but retained.
Routes originated by this device
The number of VPNv4 routes in the BGP route table that this device originated.
The number of VPNv4 routes in the BGP route table that this device has selected as the best routes to the destinations.
The number of BGP VPNv4 routes that are the best BGP VPNv4 routes to their destinations but were not installed in the IP route table because the device received better routes from other sources.
The number of routes in the BGP route table whose destinations are unreachable because the next hop is unreachable.
The number of "best" routes in the BGP VPNv4 route table that are IBGP routes.
The number of "best" routes in the BGP VPNv4 route table that are EBGP routes.
