device(config-routr-mpls)# path sf_to_sj
device(config-router-mpls-path-sf_to_sj)# insert 2.3.4.5 strict before 1.2.3.4
device(config-router-mpls-path-sf_to_sj)# exit
The following example show inserting strict node 10.150.1.1 in the path before node 10.150.1.2.
device# configure device(config)#router mpls device(config-router-mpls)# path sf_to_sj device(config-router-mpls-path-sf_to_sj)# insert 2.3.4.5 strict before 1.2.3.4 device(config-router-mpls-path-sf_to_sj)# exit
When the user modifies a path, the changes are not carried over to active LSPs that see the path until the LSPs are deactivated and reactivated. For example, path sj_to_sf may be used by an LSP called lsp1. After lsp1 has been activated, any changes to path sj_to_sf do not cause the route followed by lsp1 to be modified. To get the LSP to use the modified path, the user must deactivate and then reactivate lsp1.
