When a signaled LSP is enabled, the ingress LER attempts to connect to the egress LER over the primary path specified in the LSPs configuration. When the connection is not successful, by default the ingress LER waits 30 seconds before attempting the connection again. The user can configure the amount of time the ingress LER waits between connection attempts.
To specify, for example, a retry time of 45 seconds, complete the following steps.
device# configure
device(config)# router mpls
device(config-router-mpls)# policy
device(config-mpls-policy)# retry-time 45
The following example shows how to set the retry time to 45 seconds.
device# configure terminal device(config)# router mpls device(config-router-mpls)# policy device(config-router-mpls-policy)# retry-time 45
