The number of LDP ECMP paths for transit LSR depends on the number of eligible paths that are available, and the maximum number of LDP ECMP paths that you can configure. By default, the maximum number of LDP ECMP paths is one.
To change the maximum number of LDP ECMP paths, perform the following steps.
device# configure terminal
device(config)# router mpls
device(config-router-mpls)# ldp
device(config-router-mpls-ldp)# load-sharing 4
device# show mpls ldp Label Distribution Protocol version 1 LSR ID: 10.125.125.1, using Loopback 1(deleting it stops LDP) Hello interval: Link 5 sec, Targeted 15 sec Hold time value sent in Hellos: Link 15 sec, Targeted 45 sec Keepalive interval: 6 sec, Hold time multiple: 6 intervals load-sharing 4
The load sharing configuration is displayed only when the configured value is different from the default value.The following example shows the previous steps to change the maximum number of ECMP paths.
device# configure terminal device(config)# router mpls device(config-router-mpls)# ldp device(config-router-mpls-ldp)# load-sharing 4
