The device constantly gathers RSVP statistics. RSVP statistics are collected from the time RSVP is enabled, as well as from the last time the RSVP statistics counters were cleared.
device# clear mpls rsvp statistics
This command resets the counters listed under "since last clear" for the show mpls rsvp interface detail and the show mpls rsvp statistics commands.
An addition command that displays the same information is the show mpls rsvp statistics command.
device# show mpls rsvp statistics Total Since last clear PacketType Sent Received Sent Received Path 4 4 4 4 Resv 4 4 4 4 PathErr 0 0 0 0 ResvErr 0 0 0 0 PathTear 0 0 0 0 ResvTear 0 0 0 0 ResvConf 0 0 0 0 Errors Total Since last clear Rcv pkt bad length 0 0 Rcv pkt unknown type 0 0 Rcv pkt bad version 0 0 Rcv pkt bad cksum 0 0 Memory alloc fail 0 0 Rcv pkt processing error: Path 0 0 Resv 0 0 PathErr 0 0 ResvErr 0 0 PathTear 0 0 ResvTear 0 0 ResvConf 0 0
