To set the from address for dynamic bypass LSPs, complete the following steps.
device>configure
device(config)# router mpls
device(config-router-mpls)# mpls-interface ethernet 0/8
device(config-router-mpls-if-ethernet-0/8)# dynamic-bypass
device(config-router-mpls-if-ethernet-0/8-dynamic-bypass)# from 11.11.11.11
The following example combines the steps above to configure the from command IP address for dynamic bypass LSPs to 11.11.11.11.
device>configure device(config)# router mpls device(config-router-mpls)# mpls-interface ethernet 0/8 device(config-router-mpls-if-ethernet-0/8)# dynamic-bypass device(config-router-mpls-if-ethernet-0/8-dynamic-bypass)# from 11.11.11.11
