Displaying the best VPNv4/VPNv6 routes
To display all the VPNv4 routes in the BGP VPNv4 route table for the Extreme device that are the best routes to their destinations, enter a command such as the following at any level of the CLI.
        device(config-bgp-router)# show ip bgp vpnv4 routes best
Total number of BGP Routes: 28
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED
       E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH S:SUPPRESSED F:FILTERED
       Prefix             Next Hop        Metric     LocPrf     Weight Status
Route Distinguisher: 4:1
1      3.0.0.0/8          192.168.4.106              100        0      BE
         AS_PATH: 65001 4355 701 80
2      4.0.0.0/8          192.168.4.106              100        0      BE
         AS_PATH: 65001 4355 1
3      4.60.212.0/22      192.168.4.106              100        0      BE
         AS_PATH: 65001 4355 701 1 189
4      6.0.0.0/8          192.168.4.106              100        0      BE
         AS_PATH: 65001 4355 3356 7170 1455
5      9.2.0.0/16         192.168.4.106              100        0      BE
Syntax: show ip bgp vpnv4 routes best
For information about the fields in this display, see the Displaying the VPNv4 route table task.
