When the ingress LER fails to connect to the egress LER in a signaled LSP, the ingress LER tries indefinitely to make the connection unless the user sets a limit for these connection attempts.
To set the number of collection attempts, complete the following steps.
device# configure
device(config)# router mpls
device(config-router-mpls)# policy
device(config-mpls-policy)# retry-limit 20
In the following example, the retry limit is configured with a value of 20.
device# configure device(config)# router mpls device(config-router-mpls)# policy device(config-router-mpls-policy)# retry-limit 20
Once the connection is established, the retry counter is reset to zero. In the example above, when an LSP needs to be established again, the ingress LER makes 20 attempts to establish a connection to the egress LER.
