When both sides of a link support wish to participate in Hello message processing, the RSVP-TE Hello process follows this procedure.
When generating a message containing a HELLO REQUEST object, the sender fills in the Src_Instance field with a value representing its per neighbor instance. This value does not change while the agent is exchanging Hellos with the corresponding neighbor. The sender also fills in the Dst_Instance field with the Src_Instance value most recently received from the neighbor. For reference, refer to this variable as the Neighbor_Src_Instance. If no value has ever been received from the neighbor or this node considers communication to the neighbor to have been lost, the Neighbor_Src_Instance is set to zero (0). The generation of a message must be suppressed when a HELLO REQUEST object is received from the destination node within the prior hello-interval interval.
On receipt of a message containing a HELLO REQUEST object, the receiver generates a Hello message containing a HELLO ACK object. The receiver also verifies that the neighbor has not reset. This is done by comparing the sender's Src_Instance field value with the previously received value. If the Neighbor_Src_Instancevalue is zero, and the Src_Instance field is non-zero, the Neighbor_Src_Instance is updated with the new value. If the value differs, then the node treats the neighbor as if communication has been lost.
The receiver of a HELLO REQUEST object also verifies that the neighbor is reflecting back the receiver's Instance value. This is done by comparing the received Dst_Instance field with the Src_Instance field value most recently transmitted to that neighbor. If the neighbor continues to advertise a wrong non-zero value after a configured number of intervals (hello-tolerance), then the node must treat the neighbor as if communication has been lost.
On receipt of a message containing a HELLO ACK object, the receiver must verify that the neighbor has not reset. This is done by comparing the sender's Src_Instance field value with the previously received value. If the Neighbor_Src_Instancevalue is zero, and the Src_Instance field is non-zero, the Neighbor_Src_Instance is updated with the new value. If the value differs or the Src_Instance field is zero, then the node must treat the neighbor as if communication has been lost.
If no Instance values are received, through either REQUEST or ACK objects, from a neighbor within a configured number of hello-intervals (hello-tolerance), then a node must presume that it cannot communicate with the neighbor. The default for this number is three (3). So, the time-out is equal to three times the retransmission period. The range for hello-tolerance is 1 to 255.
For RSVP sessions with no backup available, these sessions are brought down.
For RSVP sessions with available backups, FRR switchover is performed.
The HELLO mechanism is intended for use between immediate neighbors. So, when the HELLO messages are being exchanged between immediate neighbors, the IP TTL field of all outgoing HELLO messages is set to 1.
