The following example describes LDP route injection of routes 10.2.2.2/32 and 10.5.5.2/32 into the LDP label information database.
By default, the LDP label information database only contains labels learned for IP addresses of loopback interfaces, as demonstrated in this example, where only prefixes 10.3.3.3/32 and 10.5.5.5/32 are displayed by the show mpls ldp database command.
device# show mpls ldp database Session 10.3.3.3:0 - 10.5.5.2:0 Downstream label database: Label Prefix State 1024 10.3.3.3/32 Retained Upstream label database: Label Prefix 3 10.3.3.3/32 3 10.5.5.5/32
A filter is configured to inject route 10.2.2.2/32.
device# configure terminal device(config)#ip prefix-list list1 permit 10.2.2.2/32 device(config)# router mpls device(config-mpls)# ldp device(config-router-mpls-ldp)# advertise-fec list1 device(config-router-mpls-ldp)# Ctrl-z
The show mpls ldp database command displays that route 10.2.2.2/32 has been injected into the LDP Label information database.
device# show mpls ldp database Session 10.3.3.3:0 - 10.5.5.2:0 Downstream label database: Label Prefix State Upstream label database: Label Prefix 3 10.2.2.2/32
A second filter is configured to inject route 10.5.5.2/32.
device# configure terminal device(config)# ip prefix-list list1 permit 10.5.5.2/32 device(config)# exit
The show mpls ldp database command displays that route 10.5.5.2/32 has been injected into the LDP label information database.
device# show mpls ldp database Session 10.3.3.3:0 - 10.5.5.2:0 Downstream label database: Label Prefix State Upstream label database: Label Prefix 3 10.2.2.2/32 3 10.5.5.2/32
