Displaying OSPF external link state information for a VRF
To display OSPF External Link State Information for a specified VRF, enter the following command at any level of the CLI.
        device# show ip ospf vrf green database external-link-state
Index Aging  LS ID           Router          Netmask  Metric    Flag
1     491    10.30.1.6       10.5.1.3        ffffffff 00000001  0000
2     1005   10.40.1.30      192.168.201.1   ffffffff 8000000a  0000
3     765    10.60.1.10      192.168.201.1   ffffffff 8000000a  0000
4     1005   10.40.1.9       192.168.201.1   ffffffff 8000000a  0000
5     491    10.30.1.19      10.5.1.3        ffffffff 00000001  0000
6     765    10.60.1.23      192.168.201.1   ffffffff 8000000a  0000
7     1005   10.40.1.22      192.168.201.1   ffffffff 8000000a  0000
8     765    10.60.1.2       192.168.201.1   ffffffff 8000000a  0000
9     1005   10.40.1.1       192.168.201.1   ffffffff 8000000a  0000
10    491    10.30.1.11      10.5.1.3        ffffffff 00000001  0000
11    765    10.60.1.15      192.168.201.1   ffffffff 8000000a  0000
12    1005   10.40.1.14      192.168.201.1   ffffffff 8000000a  0000
13    491    10.30.1.24      10.5.1.3        ffffffff 00000001  0000
14    491    10.30.1.3       10.5.1.3        ffffffff 00000001  0000
Syntax: show ip ospf vrf vrf-name database external-link-state [ advertise num ] | [ extensive ] | [ link-state-id ip-addr ] | [ router-id ip-addr ] | [ sequence-number num(Hex) ] | [ status num ]
The vrf-name parameter specifies the VRF that the user wants to display OSPF external link state information for.
The advertisenum parameter displays the data in the specified LSA packet. The num parameter identifies the LSA packet by its position in the Extreme device‘s External LSA table. To determine an LSA packet‘s position in the table, enter the show ip ospf vrf vrf-nameexternal-link-state command to display the table.
The extensive option displays the data in the LSAs in decrypted format.
The link-state-idip-addr parameter displays the External LSAs for the LSA source specified by IP-addr .
The router-idip-addr parameter shows the External LSAs for the specified OSPF router.
The statusnum option shows status information.
The sequence-numbernum (Hex) parameter displays the External LSA entries for the specified hexadecimal LSA sequence number.
