Displaying routes summary for a specified VPNv4/VPNv6 neighbor
To view the route table for a specified VPNv4 neighbor, enter the following command.
      device# show ip bgp vpnv4 neighbor 10.10.2.3 routes-summary
1   IP Address: 10.10.2.3
Routes Accepted/Installed:30,  Filtered/Kept:0,  Filtered:0
   Routes Selected as BEST Routes:30
      BEST Routes not Installed in IP Forwarding Table:0
   Unreachable Routes (no IGP Route for NEXTHOP):0
   History Routes:0
NLRIs Received in Update Message:30,  Withdraws:0 (0),  Replacements:0
   NLRIs Discarded due to
      Maximum Prefix Limit:0, AS Loop:0
      Invalid Nexthop:0, Invalid Nexthop Address:0.0.0.0
      Duplicated Originator_ID:0, Cluster_ID:0
Routes Advertised:154,  To be Sent:0,  To be Withdrawn:0
NLRIs Sent in Update Message:154,  Withdraws:0,  Replacements:0
Peer Out of Memory Count for:
   Receiving Update Messages:0, Accepting Routes(NLRI):0
   Attributes:0, Outbound Routes(RIB-out):0 Outbound Routes Holder:0
This display shows the following information.
Table 1. BGP4 route summary information for a VPNv4 neighbor
This field...
Displays...
Routes Accepted or Installed
How many routes the has received from the neighbor during the current BGP4 session:
  • Filtered - Indicates how many of the received routes the device filtered and did not accept.
  • Filtered or kept - Indicates how many of the received routes the device did not accept or install because they were denied by filters.
The number of routes that the device selected as the best routes to their destinations.
The number of routes received from the neighbor that are the best BGP4 routes to their destinations, but were nonetheless not installed in the IP route table because the device received better routes from other sources (such as OSPF, RIP, or static IP routes).
Unreachable Routes
The number of routes received from the neighbor that are unreachable because the device does not have a valid RIP, OSPF, or static route to the next hop.
History Routes
The number of routes that are down but are being retained for route flap dampening purposes.
The number of routes received in Network Layer Reachability (NLRI) format in UPDATE messages:
  • Withdraws - The number of withdrawn routes the device has received.
  • Replacements - The number of replacement routes the device has received.
Indicates the number of times the device discarded an NLRI for the neighbor due to the following reasons:
  • Maximum Prefix Limit - The configured maximum prefix amount had been reached.
  • AS Loop - An AS loop occurred. An AS loop occurs when the BGP4 AS-path attribute contains the local AS number.
  • Invalid Nexthop - The next hop value was not acceptable.
  • Duplicated Originator_ID - The originator ID was the same as the local device ID.
  • Cluster_ID - The cluster list contained the local cluster ID, or contained the local device ID (see above) when the cluster ID is not configured.
Routes Advertised
The number of routes the device has advertised to this neighbor:
  • To be Sent - The number of routes the device has queued to send to this neighbor.
  • To be Withdrawn - The number of NLRIs for withdrawing routes the device has queued up to send to this neighbor in UPDATE messages.
The number of NLRIs for new routes the has sent to this neighbor in UPDATE messages:
  • Withdraws - The number of routes the device has sent to the neighbor to withdraw.
  • Replacements - The number of routes the device has sent to the neighbor to replace routes the neighbor already has.
Statistics for the times the device has run out of BGP4 memory for the neighbor during the current BGP4 session:
  • Receiving Update Messages - The number of times UPDATE messages were discarded because there was no memory for attribute entries.
  • Accepting Routes (NLRI) - The number of NLRIs discarded because there was no memory for NLRI entries. This count is not included in the Receiving Update Messages count.
  • Attributes - The number of times there was no memory for BGP4 attribute entries.
  • Outbound Routes (RIB-out) - The number of times there was no memory to place a "best" route into the neighbor's route information base (Adj-RIB-Out) for routes to be advertised.
