Configuration Considerations for Enabling MPLS on a LAG Interface
When MPLS is globally enabled on the device, a port that is configured in a LAG can be enabled as an MPLS interface port to create an MPLS LAG. The user can do this through either of the following approaches:
The user must consider the following points when configuring MPLS on a LAG:
A hashing scheme for enhanced load balancing allows MPLS transit load balancing to include inner headers of different packet types in parallel. This hashing scheme is supported only with the "Layer 2 Optimized" Tcam profile and is enabled by default when the profile tcam layer2-optimised-1 configuration is activated. The "Error: Operation not supported in the current hardware TCAM profile" message is displayed for the following commands because these functionalities are already taken care of by this enhanced hashing scheme:
For more information, see "MPLS transit load balancing" under "LAG load sharing" in the Extreme SLX-OS Layer 2 Switching Configuration Guide.
