Soft-preemption Cleanup-timer
Use the soft-preemption cleanup-timer command to set the amount of time that the point of preemption must wait to receive the Path tear notification from the ingress LSR, before sending a hard preemption path error.
  1. Configure the device.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enter the policy parameters.
    device(config-router-mpls)# policy
  4. Configure the policy parameters.
    device(config-router-mpls-policy)# soft-preemption cleanup-timer 30
The following example shows setting the soft-preemption timer to 30.
device# configure
