In addition to configuration information, you can display the following LDP-IGP synchronization information.
To display LDP-IGP synchronization, use the show mpls ldp session command. When the timers are running, the remaining time appears without a refresh as well as the static value of the timer.
device# show mpls ldp session 10.7.7.2 0 Peer LDP ID: 10.7.7.2:0, Local LDP ID: 10.1.7.1:0, State: Operational Adj: Link, Role: Passive, Next keepalive: 1 sec, Hold time left: 31 sec Keepalive interval: 6 sec, Max hold time: 36 sec Up time: 16 min 46 sec TCP connection: 10.1.7.1:646--10.7.7.2:9004, State: ESTABLISHED Neighboring interfaces: Eth 2/2 Next-hop addresses received from the peer:4 10.1.1.14 10.1.2.14 10.3.4.5 10.7.7.2 IGP Sync: Unrecognized Notification Capability: Local: On, Remote: On Local State: In-sync, RemoteState: In-sync Rx label silence time: 1000 ms, Timer not running Graceful restart: enabled Peer reconnect time(msec): 120000, peer recovery time(msec): 0 State: not started
To display whether LDP-IGP synchronization is enabled on the interface, use the show mpls ldp interface command.
device# show mpls ldp int e2/16 e2/16, label-space ID: 0 Nbr count: 1 Hello interval: 5 sec, next hello: 2 sec Hello timeout: 15 sec Current IGP Sync state: In Sync
To display the current cached LDP-IGP synchronization state, use the show mpls interface command.
device# show mpls int e2/2 Admin: Up Oper: Up Maximum BW: 0 kbps, maximum reservable BW: 0 kbps Admin group: 0x00000000 Reservable BW [priority] kbps: [0] 0 [1] 0 [2] 0 [3] 0 [4] 0 [5] 0 [6] 0 [7] 0 Last sent reservable BW [priority] kbps: [0] 0 [1] 0 [2] 0 [3] 0 [4] 0 [5] 0 [6] 0 [7] 0 LDP tunnel count: 0 Current IGP Sync State: not-in-sync
