The following figure illustrates a configuration example of three LDP-enabled LSRs.
The following example provides the configuration of the LSR on each router.
R1(config)# interface loopback 1 R1(config-lbif-1)# ip address 10.1.1.1/32 R1(config-lbif-1)# exit R1(config)# router mpls R1(config-router-mpls)# mpls-interface ethernet 0/10 R1(config-router-mpls-if-ethernet-0/10)# ldp-params R1(config-router-mpls-if-ethernet-0/10-ldp-params)# ldp-enable R1(config-router-mpls)# exit R1(config)# ip route 10.2.2.2/32 10.1.1.2 R1(config)# ip route 10.3.3.3/32 10.1.1.2 R1(config)# route-only R1(config)# interface ethernet 0/10 R1(config-if-ethernet-0/10)# ldp-params R1(config-if-ethernet-0/10-ldp-params)# enable R1(config-if-ethernet-0/10-ldp-params)# ip address 10.1.1.1/24 R1(config-if-ethernet-0/10-ldp-params)# exit R1(config)# interface ethernet 0/20 R1(config-if-ethernet-0/20)# ldp-params R1(config-if-ethernet-0/20-ldp-params)# enable R1(config-if-ethernet-0/20-ldp-params)# ip address 10.1.1.1/24
R2(config)# interface loopback 1 R2(config-lbif-1)# ip address 10.2.2.2/32 R2(config-lbif-1)# exit R2(config)# router mpls R2(config-router-mpls)# mpls-interface ethernet 0/10 R2(config-router-mpls-if-ethernet-0/10)# ldp-params R2(config-router-mpls-if-ethernet-0/10-ldp-params)# ldp-enable R2(config-router-mpls-if-ethernet-0/10-ldp-params)# exit R2(config)# ip route 10.1.1.1/32 10.1.1.1 R2(config)# ip route 10.3.3.3/32 10.1.1.1 R2(config)# route-only R2(config)# interface ethernet 0/20 R2(config-if-ethernet-0/20)# ldp-params R2(config-if-ethernet-0/10-ldp-params)# enable R2(config-if-0/20)# ip address 10.1.1.2/24 R2(config-if-0/20)# exit
R3(config)# interface loopback 1 R3(config-lbif-1)# ip address 10.3.3.3/32 R3(config-lbif-1)# exit R3(config)# router mpls R3(config-router-mpls)# mpls-interface ethernet 0/10 R3(config-router-mpls-if-ethernet-0/10)# ldp-params R3(config-router-mpls-if-ethernet-0/10-ldp-params)# ldp-enable R3(config-router-mpls-if-ethernet-0/10-ldp-params)# exit R3(config)# ip route 10.1.1.1/32 10.1.1.1 R3(config)# ip route 10.2.2.2/32 10.1.1.1 R3(config)# route-only R3(config)# interface ethernet 0/20 R3(config-if-ethernet-0/20)# ldp-params R3(config-if-ethernet-0/20-ldp-params)# enable R3(config-if-ethernet-0/20-ldp-params)# 10.1.1.2/24 R3(config-if-ethernet-0/20-ldp-params)# exit
