The Egress Router 5 display
The following display examples are from Egress Router 5. Displays are shown for the show mpls rsvp session and show mpls rsvp session detail commands.
The display for Egress Router 5, shows an Egress Detour (DE) path and a path without a code that identifies a protected path. Both paths are shown from Ingress Router 4 at Loopback IP address 10.4.4.4 to Egress Router 5 at Loopback IP address 10.5.5.5. The primary path traverses Transit Routers 2 and 6. In the case of the DE path, a reroute sends traffic through Transit Routers 3 and 1.
device5# show mpls rsvp session
Codes: DI:Ingress Detour  DT:Transit Detour  DM:Merged Detour
       DE:Egress Detour  RP:Repaired Session
Ingress RSVP:     0 session(s)
Transit RSVP:     0 session(s)
Egress RSVP:      1 session(s)
To                From            St    Style Lbl_in Lbl_out LSPname
10.5.5.5          10.4.4.4(DE)    Up    SE    3      0       1
10.5.5.5          10.4.4.4        Up    SE    3      0       1
The following example displays the output from Egress Router 5 using the show mpls rsvp session detail command. This command provides additional details about the paths described in the output from the show mpls rsvp session command.
For the DE path, two PLR and Avoid Node ID pairs are shown labeled [1] and [2]. In both the Point of Local Repair (PLR) is at IP Address 10.13.13.1 which is the interface to the primary path on Ingress Router 4. The Avoid Node for pair [1] is IP address 10.13.13.2 on Transit Router 2 and the Avoid Node for pair [2] is IP address 10.18.18.2 on Transit Router 6.
The "Fast Reroute" field indicates that the primary path has been configured for one-to-one backup.
There is no "Explicit path hop count" field for either route because Egress Router 5 is the destination of the path.
device5# show mpls rsvp session detail
  Time left in seconds (PATH refresh: 18, ttd: 149
                        RESV refresh: 7, ttd: 152)
  Tspec: peak 0 kbps rate 0 kbps size 0 bytes m 20 M 1500
  Detour Rcvd: Number of PLR and Avoid Node ID pair(s): 2
   [1]: PLR: 10.13.13.1  Avoid Node: 10.13.13.2
   [2]: PLR: 10.13.13.1  Avoid Node: 10.18.18.2
  PATH rcvfrom: 10.15.15.1      (e8/2          ) (MD5 OFF)
To                From            St    Styl Lbl_in Lbl_outm LSPname
  Time left in seconds (PATH refresh: 30, ttd: 152
  Fast Reroute: one-to-one backup desired
   Setup priority: 7, hold priority: 0
   Bandwidth: 0 kbps, hop limit: 255
PATH rcvfrom: 10.19.19.2      (e8/1) (MD5 OFF)
