To set the explicit path for dynamic LSPs, complete the following steps.
device>configure
device(config)# router mpls
device(config-router-mpls)# mpls-interface ethernet 0/8
device(config-router-mpls-if-ethernet-0/8)# dynamic-bypass
device(config-router-mpls-if-ethernet-0/8-dynamic-bypass)# primary-path dbyp-path
The following example combines the steps above to set an explicit path with the name of dbyp-path, for dynamic bypass LSPs.
device>configure device(config)# router mpls device(config-router-mpls)# mpls-interface ethernet 0/8 device(config-router-mpls-if-ethernet-0/8)# dynamic-bypass device(config-router-mpls-if-ethernet-0/8-dynamic-bypass)# primary-path dbyp-path
