This section lists the power accessories that are compatible with the 802.11ax access points.
All power cables and accessories must be purchased separately. Use the power accessory part number provided in the following tables to purchase the correct power accessory for your access point.
You should check End of Sale announcements regularily so you have access to the latest equipment.
