This section lists the power accessories that are compatible with the 802.11ax access points.
All power cables and accessories must be purchased separately. Use the power accessory part number provided in the following table to purchase the correct power accessory for your access point.Power accessory part number | Description | Access point compatibility | |||
Indoor access points | Outdoor access points | ||||
AP305C/CX | AP410C | AP510C/CX | AP460C, AP460S6C, and AP460S12C | ||
PD-3501G-ENT | Indoor single port 802.3af compliant mid span | ✓ | ✓ | ✓ | — |
AH-ACC-PW-30W | 30W power adapter (12VDC, 2.5A) | — | — | ✓ | — |
AH-ACC-PW-CBL-US | 6 ft. 18 AWG universal power cord with United States plug | ✓ | ✓ | ✓ | — |
AH-ACC-PW-CBL-UK | 6 ft. universal power cord with United Kingdom plug | ✓ | ✓ | ✓ | — |
AH-ACC-PW-CBL-EU | 6 ft. universal power cord with European Union plug | ✓ | ✓ | ✓ | — |
AH-ACC-PW-CBL-AU | 6 ft. universal power cord with Australia plug | ✓ | ✓ | ✓ | — |
AH-ACC-PW-CBL-JP | 6 ft. universal power cord with Japan plug | ✓ | ✓ | ✓ | — |
AH-ACC-PW-CBL-KR | 6 ft. universal power cord with Korea plug | ✓ | ✓ | ✓ | — |
PD-9001GO-ENT | Outdoor 802.3at compliant PoE single port mid span | ✓ | ✓ | ✓ | ✓ |
PD-9001GR-ENT | Indoor 802.3at compliant single port mid span | ✓ | ✓ | ✓ | ✓ |
The mid spans do not ship with a power cord. For the mid span power cords, the installer must supply appropriate AC plug for power connection.Key | Description |
✓ | Compatible |
— | Not compatible |
AC cable | Line | Neutral | Earth ground |
US cable | Black | White | Green |
EU cable | Brown | Blue | Yellow-green |
