You can change the number of paths IPv6 IS-IS can calculate and install in the IPv6 forwarding table. If you change the number of paths to one, the device does not load share multiple route paths learned from IPv4 IS-IS.
By default, IPv6 IS-IS can calculate and install eight equal-cost paths into the IPv4 forwarding table.
