Describes the process of configuring Resilient Hashing on the SLX devices.
Resilient Hashing is available for default VRF as well as user created VRFs. To configure Resilient Hashing on default VRF:
  1. Navigate to the Configuration context using the conf term command.
    SLX# conf term
    SLX(config)#
  2. Use the resilient-hash command to configure.
    SLX (config)# resilient-hash ?
    Possible completions:
        ecmp        Resilient hash ECMP
        max-path    Resilient hash max path (8|16|64)
    SLX (config)# resilient-hash ecmp ?
        enable      Enable resilient hash ECMP
    SLX (config)# resilient-hash ecmp enable
  3. Configure the max-path value.
    The default max-path value is 8. You can choose to use 8, 16, or 64 paths.
    SLX (config)# resilient-hash max-path 8
    SLX (config)#
  4. Verify the configuration using the show ip route system-summary command.
    SLX # show ip route system-summary
    System Route Count: 10 Max routes: 358400 (Route limit not exceeded)
    System Nexthop Count: 2 Max nexthops: 4000 (Nexthop limit not exceeded)
    One Path Nexthop Count: 1 Max One Path Nexthops: 48000
    RH Flowset Entries: 2816 Max 32768 (Flowset limit not exceeded)
    VRF-Name: default-vrf
        Route count: 0 Max routes: Not Set (Route limit not exceeded)
        0 connected, 0 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
        Resilient Hashing (Flowset Sz: 128, Max RH Paths: 8, RH Nexthops: 12)
    VRF-Name: mgmt-vrf
        Route count: 3 Max routes: Not Set (Route limit not exceeded)
        1 connected, 1 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
    VRF-Name: vrf2
        Route count: 7 Max routes: Not Set (Route limit not exceeded)
        2 connected, 2 static, 0 OSPF, 1 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
        Resilient Hashing (Flowset Sz: 128, Max RH Paths: 16, RH Nexthops: 10)
    VRF-Name: vrf3
    SLX #
