Router-ID IP Addresses
Certain routing protocols, such as OSPF
and BGP4, have algorithms that specify which configured IP address identifies the device.
In general, a device has IP addresses that are
assigned to various interfaces. However, some routing protocols identify the device by
the router ID, rather than by the IP addresses assigned to the interfaces connected by
the protocol. If a router ID is not specified, such protocols use the following
algorithm to select a router ID.
- If the device has loopback
interfaces, the router ID is the IP address on the loopback interface with the
lowest IP address. For example, if you configure loopback interfaces 1, 2, and 3
as follows, the default router ID is 10.9.9.9/32:
- Loopback 1: 10.9.9.9/32
- Loopback 2: 10.4.4.4/32
- Loopback 3: 10.1.1.1/32
- If a loopback interface is not
configured, then the lowest IP address configured on a physical interface
becomes the router ID.
You can also specify a router-id IP address, using the
ip router-id command.
