You can configure summary prefixes to aggregate IS-IS IPv6 route information. Summary prefixes can enhance performance by reducing the size of the Link State database, reducing the amount of data the device needs to send to its neighbors, and reducing the CPU cycles used for IPv6 IS-IS. The following task configures a summary prefix 2001:db8::/32 for Level 1 routes.
device# configure terminal
device(config)# router isis
device(config-isis-router)# address-family ipv6 unicast
device(config-router-isis-ipv6u)# summary-prefix 2001:db8::/32 level-1
The following example configures asummary-prefix of 2001:db8::/32 for Level 1 routes.
device# configure terminal device(config)# router isis device(config-isis-router)# address-family ipv6 unicast device(config-router-isis-ipv6u)# summary-prefix 2001:db8::/32 level-1
