Configure BFD for IS-IS Globally
BFD for IS-IS can be configured globally on interfaces where BFD has been configured.
Enable BFD on IS-IS interfaces. For more information, see Enable BFD on an IS-IS-enabled Interface.
  1. Access global configuration mode.
    device# configure terminal
  2. Access ISIS router configuration mode.
    device(config)# router isis
  3. Enable BFD globally.
    device(config-isis-router)# bfd
  4. Specify the interval after which routes are withdrawn after a BFD session is declared down.
    device(config-isis-router)# bfd holdover-interval 12
    This example specifies a holdover interval of 12 seconds.
