You can enable Proxy ARP on a physical or VE interface.
Proxy ARP is disabled by default.
  1. Access global configuration mode.
    device# configure terminal
  2. Access the interface on which you are enabling Proxy ARP.
    device(config)# interface ethernet 0/1
  3. Enable Proxy ARP.
    device(conf-if-eth-0/1)# ip proxy-arp
The following example summarizes the commands in this procedure.
