            The following guidelines apply to:
Extreme
				Networks
                recommends that all connections between the AP and antennas are weatherproofed using
                the following weatherproof kits (not supplied):
                    - Wireless Weatherproofing
                            Kits:
                            - 3M (WK‐100)
                            - Scotch (WK‐101)
Each weatherproofing kit includes ¾-inch vinyl tape, 2-inch mastic
                        tape, and 2-inch wide vinyl tape.
Follow the guidelines to ensure proper installation:
                - The weatherproofing tape must be
                    wound tightly over the connectors.
                - Ensure that no areas around the
                    edges are exposed.
Installation instructions are
                provided with each weatherproofing kit.
            Weatherproofing the
                    Antenna
                            | 1 |
                            Antenna |
                            4 |
                            Type-N jack  |
                            | 2 |
                            Nut |
                            5 |
                            AP |
                            | 3 |
                            Standard polarity Type-N plug |
                            6 |
                            Sealing tape (recommended, but not supplied) |
