Antenna Compatibility Matrix
The following tables list the indoor and outdoor antennas, and the corresponding supported access points. You can use this information to guide you when you install your access points.
For more information, see AP510CX and AP305CX Access Points Antennas Support Country List.
Some deployment scenarios require an adapter. For the adapter technical specifications, see "Supported Antenna Adapters" in the Enterprise Wireless LAN Antenna Specification Guide.
Indoor Antennas
The following table list the indoor antennas, and the corresponding supported access points.
The indoor antennas listed in the following table are not compatible with Extreme outdoor APs, including the AP460e and AP360e.
Table 1. Indoor Antenna Compatibility Matrix - Indoor APs
Antenna Indoor APs
Non-Cloud Enabled APs Cloud Enabled APs
AP510e AP410e AP310e AP510CX AP305CX AP3000X
WS-AI-DQ05120 ✓ ✓ ✓ — — —
WS-AI-5Q04060 (30703) ✓ ✓ — — — —
WS-AI-2Q05060 (30704) ✓ — — — — —
WS-AI-DE07025 (30705) ✓ ✓ ✓ — — —
WS-AI-5Q05025 (30706) ✓ ✓ — — — —
WS-AI-DE10055 (30707) ✓ ✓ ✓ — — —
ML-2452-PTA4M4-036 ✓ ✓ ✓ — ✓ —
ML-2452-PTA2M2-036 ✓ ✓ ✓ — ✓ —
ML-2452-SEC6M4-036 ✓ ✓ ✓ ✓ ✓ —
ML-2452-APA2-01
(black)
ML-2452-APA2-02
(white)
ML-2452-HPA5-036 ✓ ✓ ✓ — — ✓
AI-DQ04360S ✓ ✓ ✓ ✓ ✓ —
AH-ACC-ANT-AX-KT
(pack of 8 dual-band)
AI-DS0305360-RPSMA — — — — —
AIO-DD75060-RPSMA — — — — — ✓
AIO-DD05120-RPSMA — — — — — ✓
AI-DP04360S ✓ ✓ ✓ ✓ ✓ —
Outdoor Antennas
The following tables list the outdoor antennas, and the corresponding supported access points.
The ML-2452-SEC6M4-036 and AI-DQ04360S are outdoor-rated indoor antennas. Both the antennas can be used outdoor on AP510CX and AP305CX access points.
Table 2. Outdoor Antenna Compatibility Matrix - Indoor APs
Antenna Indoor APs
AP510e, AP410e, and AP310e AP510CX and AP305CX AP3000X
ML-2452-HPAG4A6-01
Requires adapter 25-85392-01R for each port
ML-2452-PNA5-01R ✓ — ✓
ML-2452-HPAG5A8-01 ✓ — —
ML-2452-PNA7-01R ✓ — —
ML-2452-HPA6-01 — — —
ML-2452-SEC6M4-036 — ✓ —
AI-DQ04360S — ✓ —
WS-AO-DQ05120N (30711) — — —
WS-AO-5Q04060N (30712) — — —
WS-AO-5Q05025N (30716) — — —
WS-AO-DQ04360N (30724) — — —
Table 3. Outdoor Antenna Compatibility Matrix - Outdoor APs
Antenna Outdoor APs
AP460e AP360e
ML-2452-HPAG4A6-01 ✓ ✓
ML-2452-PNA5-01R ✓ ✓
ML-2452-HPAG5A8-01 ✓ ✓
ML-2452-PNA7-01R ✓ ✓
ML-2452-HPA6-01 ✓ ✓
ML-2452-SEC6M4-036 — —
AI-DQ04360S — —
WS-AO-DQ05120N (30711) ✓ ✓
WS-AO-5Q04060N (30712) ✓ —
WS-AO-5Q05025N (30716) ✓ —
WS-AO-DQ04360N (30724) ✓ ✓
