Learn about the AH-ACC-ANT-AX-KT external antenna specifications and radiation patterns.
| Item | Description |
| Maximum power | 1 watt |
| Polarization | Linear and vertical |
| Nominal impedance | 50±10 Ω |
| VSWR | 2 |
| Radome material | Acrylonitrile Butadiene Styrene (ABS) |
| Mounting method | Direct attach |
| Frequency range | Typical gain | Azimuth beamwidth | Connector |
| 2.4 GHz – 2.5 GHz | 3±0.5 dBi | Omnidirectional | SMA |
| 5.1 GHz – 5.9 GHz | 5±0.5 dBi |
| Temperature range |
Operating temperature: −20°C to +60°C (−4°F to +140°F) Storage temperature: −20°C to +70°C (−4°F to +158°F) |
