| Parameter | Performance |
| Maximum power | 10 watts |
| Polarization | Linear, vertical |
| Nominal impedance | 50 Ω |
| VSWR | 2:1 |
| Radome material | Polycarbonate |
| Cable | 36-inches RG-58 plenum-rated cable |
| Mounting method | Beam, ceiling, or mast mount |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| ML-2452-HPA5-036 | 2.4–2.5 GHz |
With cable: 2.1 dBi Without cable: 2.9 dBi |
3.9 dBi | 360° | 44° | RP-SMA plug |
| 5.1–5.9 GHz |
With cable: 3.8 dBi Without cable: 4.9 dBi |
5.7 dBi | 18° |
| Dimensions | Weight | Temperature range |
| 25.4 mm × 245.5 mm | 0.30 lb (0.14 kg) |
Storage temperature: −40°C to +85°C (−40°F to +185°F) Operating temperature: −30°C to +70°C (−22°F to +158°F) |
