            The ML-2452-HPA6-01 is a dual-band outdoor antenna with a standard N-type plug
                connector. The antenna can be attached directly to the access point.
                Line up the antenna connector
                    against the antenna port on the access point.
                Twist the antenna connector clockwise to attach it to the antenna port.
