| Item | Description |
| Maximum power | 20 watts |
| Polarization | Dual-slant linear ±45 |
| Nominal impedance | 50 Ω |
| VSWR | 1.5–2.0 |
| Mounting method | Wall or pipe mount |
| Frequency | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| 2.4 GHz – 2.5 GHz | 5.0 dBi | 5.5 dBi | 100° | 90° | N-type |
| 5.1 GHz – 5.9 GHz | 4.5 dBi | 5.5 dBi | 80° | 80° |
| Part number | Dimensions | Weight | Temperature |
| WS-AO-DQ05120N (30711) | 200 mm × 200 mm × 34 mm | 1.00 lb (0.45 kg) | Operating temperature: −40°C to +70°C (−40°F to +158°F) |
