| Parameter | Performance |
| Maximum power | 2 watts |
| Polarization | Linear, vertical |
| Nominal impedance | 50 Ω |
| VSWR | 2:1 |
| Radome material | ASA |
| Cable | 12-inches RG-58 plenum-rated cable |
| Mounting method | Wall or pole mount |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| ML-2452-PNA7-01R | 2.4–2.5 GHz | 7.0 dBi | 7.3 dBi | 68° | 66° | Standard N-plug connector |
| 4.9–5.9 GHz | 10.5 dBi | 12.0 dBi | 52° | 60° |
| Wind rating | Dimensions | Weight | Temperature |
| 100 mph | 105.66 mm × 105.6 mm × 35.05 mm | 0.50 lb (0.23 kg) |
Storage temperature: −40°C to +85°C (−40°F to +185°F) Operating temperature: −30°C to +70°C (−22°F to +158°F) |
