| Parameter | Performance |
| Polarization | Linear, vertical |
| Nominal impedance | 50 Ω |
| VSWR |
2.4 GHz – 2.5 GHz: 2 5.1 GHz – 5.9 GHz: 2 |
| Radome material | Polycarbonate (PC) plastic |
| Cable | N/A |
| Mounting method |
Direct attach Pole attach using the pole mounting kit |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| ML-2452-HPAG4A6-01 | 2.4 GHz – 2.5 GHz | 3.0 dBi | 4.0 dBi | 360° | 53°–56° | Standard N-plug |
| 5.1 GHz – 5.9 GHz | 6.0 dBi | 7.3 dBi | 360° | 18°–22° |
| Wind rating | Dimensions | Weight | Temperature range |
| 134 mph | 280.2 × 24.8 mm | 0.31 lb (0.14 kg) | Storage temperature: −40°C to +80°C (−40°F to +176°F) |
