| Parameter | Performance |
| Maximum power | 5 watts |
| Polarization | Linear, omnidirectional |
| Nominal impedance | 50 Ω |
| VSWR | 2:1 |
| Radome material | Acrylic styrene acrylonitrile (ASA) |
| Cable | 36-inches RG-58 plenum-rated cable |
| Mounting method | Ceiling mount |
| Part number | Frequency | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| ML-2452-PTA4M4-036 | 2.4 GHz – 2.5 GHz | 4.0 dBi | 5.0 dBi | Omnidirectionality | 70° | RP-SMA plug |
| 5.1 GHz – 5.9 GHz | 5.7 dBi | 6.6 dBi | Omnidirectionality | 50° |
| Weight | Temperature |
| 1.10 lb (0.50 kg) | Storage and operating temperature: −40°C to +70°C (−40°F to +158°F) |
