After you install the indoor access point, install the ML-2452-APA2-01 or
ML-2452-APA2-02 antenna.
Line up the antenna connector
and the antenna port on the access point.
Twist the antenna connector clockwise to attach it to the antenna port.
ML-2452-APA2-01 or
ML-2452-APA2-02 antenna attached to the AP510e access
point
The ML-2452-APA-02 antenna is also used on the
AP305C/CX access point. The procedure to attach the antenna to the access point
remains the same.
