The AP3000X
is an indoor wireless access point that has two Wi-Fi 6 GHz antennas permanently
attached or integrated into the AP. The following list shows the antenna
specifications:
Antenna type: Dipole
array
Frequency: 5900 ~ 7125
MHz
Impedance: 50 Ohm
Nominal
VSWR: < 2dB
Polarization: Linear
Operating temperature: -40 ~
+80 °C
Connector: MHF
Cable type: OD 1.37 L/L
Table 1. Ports, Gain, and
Beam
Ports
2.4GHz
5GHz
6GHz
Gain
Beam
Gain
Beam
Gain
Beam
1
5.49
360
Radiation Patterns
The following diagrams show the radiation patterns for the AP3000X permanently fixed or
integrated antennas.
