| Item | Description |
| Maximum power | 20 watts |
| Polarization | Dual-slant linear ±45° |
| Nominal impedance | 50 Ω |
| Voltage Standing Wave Radio (VSWR) | 1.5 typical 2.0 maximum |
| Mounting method | Wall mount or pipe mount |
| Part number | Frequency | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| WS-AI-5Q0460 (30703) | 4.9 GHz – 6.1 GHz | 3.0 dBi | 4.0 dBi | 50° | 33° | RP-SMA plug |
| Part number | Dimensions | Weight | Temperature |
| WS-AI-5Q04060 (30703) | 200 mm × 200 mm × 34 mm | 1.00 lb (0.45 kg) | Storage temperature: −40°C to +70°C (−40°F to +158°F) |
