| Item | Description |
| Maximum power | 20 watts |
| Polarization | Dual-slat linear ±45° |
| Nominal impedance | 50 Ω |
| Voltage Standing Wave Radio (VSWR) | 1.5 typical 2.0 maximum |
| Front-to-back ratio | >20 dB |
| Radome material | UV protected plastic |
| Cable | Four 58 in. and 2 UL94 RG-316 |
| Mounting method | Wall or pipe mount |
| Part number | Frequency range | Typical gain | Peak gain | Azimuth beamwidth | Elevation beamwidth | Connector |
| WS-AI-DQ05120 (30702) | 2.4 GHz – 2.5 GHz | 5.0 dBi | 5.5 dBi | 100° | 90° | RP-SMA plug |
| 5.1 GHz – 5.9 GHz | 4.5 dBi | 5.5 dBi | 80° | 65° |
| Part number | Dimensions | Weight | Temperature |
| WS-AI-DQ05120 (30702) | 200 mm × 200 mm × 34 mm | 1.00 lb (0.45 kg) | Storage temperature: −40°C to +70°C (−40°F to +158°F) |
