Not all antennas described in this section can be used with every wireless access point. Refer to the Antenna Compatibility Matrix to determine if your access point supports the specified antenna.The fence acts as a harmonic reflector that blocks the signal.
These products can cause signal interference because they operate in the same frequency range as the device to which your antenna is connected.
The antennas ship with a standard mounting kit that allows for a 70 degree tilt. The wall extension bracket kit is an optional accessory that is used with the standard mounting kit to increase the antenna tilt, up to 90 degrees. The wall extension kit can only be used with the main mounting kit.
