The ML-2452-APA2-01 and ML-2452-APA2-02 are both dipole, dual-band RP-SMA plug connector antennas. The only difference between the antennas is the color. The ML-2452-APA2-01 is a black color antenna whereas the ML-2452-APA2-02 antenna is a white color antenna.
| Parameter | Performance |
| Maximum power | 1 watt |
| Polarization | Linear, vertical |
| Nominal impedance | 50 Ω |
| VSWR |
2.4–2.5 GHz: ≤ 1.92 5.1–5.8 GHz: ≤ 1.92 |
| Radome material | Acrylonitrile butadiene styrene (ABS) plastic |
| Cable | RG-178 |
| Mounting method | Direct-attach to the access point |
Part number |
Freq. range |
Typical gain | Peak gain |
Azimuth beamwidth |
Elev. beamwidth |
Connector |
| ML-2452-APA2-01 and ML-2452-APA2-02 | 2.4–2.5 GHz | 2.73 dBi | 3.04 dBi | 360° | 48° | RP-SMA plug |
| 5.1–5.4 GHz | 4.19 dBi | 4.30 dBi | 360° | 28° | ||
| 5.5–5.7 GHz | 4.64 dBi | 4.96 dBi | 360° | 28° | ||
| 5.7–5.8 GHz | 4.95 dBi | 4.96 dBi | 360° | 28° |
| Dimensions | Weight | Temperature range |
| 157.0 × 17.6 × 5.8 mm | 0.03 lb (0.01 kg) |
Storage temperature: −10°C to +70°C (−14°F to +158°F) Operating temperature: −10°C to +60°C (−14°F to +140°F) |
